Help with setting up Aironet 600 as a stand-alone WiFi access point wi
I purchased this to help with poor WiFi
connection in the bedroom upstairs
I’ve since realised there designed for use with a wireless LAN controller (?)
They were priced with in my limited budget and yes I now know there old stock and no longer supported. Is there any one who could help me set one of them up as a standalone AP with out a network controller
please
thanks
peter w
Scott Fella
I don’t believe this will work without a controller. You either need to look for maybe a used 2504 which can be cheap these days or find an access point that states it can be used without a controller.
-Scott
Thanks for your reply.
Before joining the Cisco community I did try to find the answer on the web.
In one of those searches some one suggested that it there was some soft
ware I could get from Cisco that allows the unit to be used and that when I
found the Cisco forum to see if that was true
Looks like another dud end wife won’t be happy!!!
Thanks for your time
Peter
Here is another reference
https://community.cisco.com/t5/wireless/question-for-air-oeap602i-e-k9/td-p/2704712
-Scott
