Hid-SSID+WEP+ACS
jorge.s
we have an implementation of Wlan distributed throughout several plant's, where there security implemented is:
1. SSID Hidden
2. 128 Fixed WEP Key
3. Cisco ACS with registration of MacAddress's
And we are then doing authentication based on Mac-Address.
We know that this is really a not safe solution, but what you would recommend, considering that we are Running Microsoft Active Directory, but avoiding the use of Certificates.
Thanks for any recomendation,
Best Regards,
Jorge Sousa
wong34539
Level 6
Level 6
When you carry multiple VLANs thru a wireless bridge link, all the VLANs are actually carried thru the native VLAN SSID, so the only crypto configuration that it actually operational is the one for that SSID
Fixed and Mobile Wireless Solution:
http://www.cisco.com/univercd/cc/td/doc/product/wireless/index.htm
Wireless Virtual LAN Deployment Guide:
http://www.cisco.com/en/US/products/hw/wireless/ps430/prod_technical_reference09186a00801444a1.html
