Hide SSID in AP
johnlloyd_13
Level 11
Level 11
hi all,
sorry for a noob question, i'm still learning wireless.
i've searched cisco and CSC on how to disable broadcasting of SSID.
i have multiple SSID on my AP.
is it normal to still see the SSID on the sh dot11 bssid command even though i disabled its broadcast?
AP(config)#dot11 ssid 3333
AP(config-ssid)#no guest-mode
AP(config-ssid)#do sh dot11 bssid
Interface      BSSID         Guest  SSID
Dot11Radio0   003a.9910.xxxx  Yes  1111
Dot11Radio0   003a.9910.yyyy  Yes  2222
Dot11Radio0   003a.9910.zzzz  Yes  3333
Leo Laohoo
You forgot your radios:
interface dot111
 no mbssid
interface dot110
 no mbssid
end
Not applicable
Leo,
what happen if WLC is configured to broadcast those SSID's?
Hi Eric,
I don't understand your question.  The command I've responded above is for an autonomous IOS.  Based on the "AP#" prompt, I'm suspecting John's AP is operating in autonomous.
hi guys,
thanks for your input!
yes, it's for an autonomous wap and i've figured it out.
the command should be 'no mbssid guest-mode' under ssid subcommad:
AP(config-ssid)#no mbssid guest-mode
