WGB
bm_5789
Level 5
Level 5
We are deploying a medical cart that contains a video camera, computer and 2600i ap.  The ap will be used as a WGB.  Our wireless environment is controller-based.  I suspect this cart will be moving around to several locations.  It is unclear to me how I will connect the WGB to a root bridge.  Can I configure my lightweight ap's to server as a root bridge and a regular ap at the same time?  Or will I have to install additional ap's to server only as root bridges?  TIA
Stephen Rodriguez
You can use a WGB with the Cisco WLC environment. You may need to issue a command:
config network ip-mac-binding disable
to allow more than one device behind the WGB to connect
http://www.cisco.com/c/en/us/td/docs/wireless/controller/7-2/configuration/guide/cg/cg_lwap.html#wp2097800
HTH,
Steve
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
Thanks for your reply.  I will try to build a lab before the cart arrives.
Hi BM,
I have about 150+ Cisco 1131s in WGB. We also have a dozen 1142 and 3500 attached to carts doing BIO med data and a Cisco VX cart doing voice and video.
Shoot me an email at g s t e f a n i c k@w i r e l e s s g u r u. net and I will share my configs to get you started.
abwahid
Level 9
Level 9
Please go through the below link for configuration example.
http://www.cisco.com/c/en/us/support/docs/wireless/4400-series-wireless-lan-controllers/100254-wgb-config.html
