High density warehouse - Access Point Positioning
dot1x
Level 5
Level 5
For a high density warehouse location, if we put APs too close to eachother, would we have co-channel interference?
Any best practices to reduce the co-channel interference in such dense areas?
Is it a good idea to use TPCv2?
Document says: TPCv2 is suitable for dense networks. In this mode, there could be higher roaming delays and coverage hole incidents.
If reducing power doesn't really work, is it a good idea to reduce the cell size by allowing only higher data rates?
Leo Laohoo
That's not an easy question to answer.  There are a lot of factors which may or may not affect co-channel interference.
  1. How "close" is "too close"?
  2. What is the channel and power of each radio?
  3. Attenuation?  Where are they?
15 to 20 m apart
  1. What is the channel and power of each radio?
Default Dynamic Settings
  1. Attenuation?  Where are they?
Warehouse with medium density
DCA assigns Power Level 7 to most of the APs.
I can also see 60 to 70 % interference.
In this case, indeed to close. With > 30% of interference, problems can start. Also with Level 7, the power is already on the lowest.
I suggest to do a site survey an completely change the placements of the APs or use external antennas, specific for your installation and site survey.
