High Gain antenna for Cisco 9120AXE
tlindley
For my Cisco 9120AXE access point, what high gain external antenna is recommended to get the WiFi 6 signal through plaster walls and ceilings?  The original 4 post antennas are not getting the job done.
I have a Cisco Aironet 5-GHz 14-dBi 2-port directional antenna available.
balaji.bandi
Has this site done site survey, if not consider doing site survey ?
Some reference antennas and their signals :
https://www.cisco.com/c/en/us/products/collateral/wireless/aironet-antennas-accessories/product_data_sheet09186a008008883b.html
BB
5 Replies 5
balaji.bandi
BB
Not yet, thank you.
Leo Laohoo
Cisco Catalyst 9120 Access Point Deployment Guide and scroll down to the Approved antennas Catalyst 9120e section.
IMPORTANT:   Get a wireless site survey done before purchasing the antennas.
Thank you!
JPavonM
You can also look at third-party antennas such those from AccelTex.
