ā06-02-2015 07:04 AM - edited ā07-05-2021 03:20 AM
I'm facing a problem with cap702i the ping response is very important around 400ms even the access point is too close and i set the data rate to start
from 5.5 every things set up as it should be please any help? to get back to the 400 ms
when we put the charger the ping goes ok until we remove it
i tried many ios starting 7.6.130 to this version but no hope .
ā06-02-2015 01:51 PM
Do you have any other AP model to test this to see if it is only happen with 702i
Rasika
ā06-02-2015 02:01 PM
hi,
Thanks for you reply .acually i used to work with 1041N model and it was ok but since we try the cap702i model i face many issue starting with DTLS problem ending with this issue.for your question i did not test another model frankly but i test many access point with this model.
ā06-04-2015 02:13 AM
Hi dridi,
can you plz explain that how did you deployed this AP, is this connected to a POE switch or using power injector?
try to check the ethernet cable test if it is connected through a switch!
ā06-04-2015 11:32 AM
hi,
the ap is connected to POE switch (2960) and for the cable actually even when two laptops are in the same Vlan the same problem occur since i make sure to use the localy switched function i assumed that there is no thing wrong with the cable.
