12-27-2016 01:36 PM - edited 07-05-2021 06:16 AM
so I bought a few 1142's and converted to Autonomous. when connected I pull a file from my smb server and get 100-108mbps throughput. coming from my apple n router (450mbps) I can pull greater than 220mbps.
I understand the 1142 is only 300, I should be able to get ~145mbps real world. I mention the apple speeds to prove that my server is capable of pushing the file. Lan I get close to full gig speeds from the server as well.
I have tried everything (I think) including no encryption, every N channel etc., am I missing something?
here is my config:
Building configuration...
Current configuration : 3658 bytes
! Last configuration change at 15:45:21 UTC Wed Dec 21 2016 by Cisco
version 15.2
no service pad
service password-encryption
hostname vpdwap01
logging rate-limit console 9
enable secret 5 $1$TsGi$Bu/b3K4cA0OAvgEGSnTju/
aaa new-model
aaa group server radius rad-group
server 10.0.4.20 auth-port 1812 acct-port 1813
aaa authentication login eap-meth group rad-group
aaa session-id common
no ip cef
dot11 syslog
dot11 ssid VPDNETWIFI
vlan 10
authentication open
authentication key-management wpa version 2
guest-mode
wpa-psk ascii 7 0518125C72401D1B0A
dot11 ssid VPDNETWIFi
vlan 11
authentication open
guest-mode
wpa-psk ascii 7 15011F5F572678363B
dot11 ssid backhaul
vlan 40
authentication open eap eap-meth
authentication network-eap eap-meth
dot11 band-select parameters
cycle-count 3
cycle-threshold 200
expire-supression 20
expire-dual-band 60
client-rssi 80
dot11 priority-map avvid
dot11 guest
username Cisco password 7 062506324F41
bridge irb
interface Dot11Radio0
no ip address
encryption vlan 11 mode ciphers aes-ccm
ssid VPDNETWIFi
antenna gain 0
beamform rssi 30
speed basic-36.0 48.0 54.0 m0. m1. m2. m3. m4. m5. m6. m7. m8. m9. m10. m11. m12. m13. m14. m15.
channel 2462
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Dot11Radio0.11
encapsulation dot1Q 11
bridge-group 10
bridge-group 10 subscriber-loop-control
bridge-group 10 spanning-disabled
bridge-group 10 block-unknown-source
no bridge-group 10 source-learning
no bridge-group 10 unicast-flooding
interface Dot11Radio1
no ip address
encryption vlan 10 mode ciphers aes-ccm
encryption vlan 40 mode ciphers aes-ccm
ssid VPDNETWIFI
ssid backhaul
antenna gain 35
peakdetect
no dfs band block
speed basic-18.0 24.0 48.0 54.0 m0. m1. m2. m3. m4. m5. m6. m7. m8. m9. m10. m11. m12. m13. m14. m15.
channel width 40-above
channel 5240
station-role root bridge wireless-clients
distance 1
interface Dot11Radio1.10
encapsulation dot1Q 10
bridge-group 10
interface Dot11Radio1.40
encapsulation dot1Q 40 native
bridge-group 1
interface GigabitEthernet0
no ip address
duplex auto
speed auto
interface GigabitEthernet0.10
bridge-group 10
interface GigabitEthernet0.11
bridge-group 10
interface GigabitEthernet0.40
bridge-group 1
interface BVI1
ip address 10.0.4.20 255.255.255.0
ip default-gateway 10.0.4.1
ip forward-protocol nd
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
radius-server local
no authentication leap
no authentication mac
nas 10.0.4.20 key 7 111F090100131B5C55
user vpdwap nthash 7 15305958260B0D740E6466014A5E375656727C0F07712B534A30087973040B0075
radius-server host 10.0.4.20 auth-port 1812 acct-port 1813 key 7 095A5E0D0E0407425A
bridge 1 route ip
line con 0
line vty 0 4
transport input all
end
12-27-2016 04:02 PM
I presume the "horrible speed" was observed with 802.11b radio and NOT 802.11a radio?
12-27-2016 04:08 PM
this is on do1. Mac shows I'm connected as N client at 40 MHz. both radios should have b disabled. do1 should be N only right? and I have tried with do0 both enabled/disabled
12-27-2016 07:02 PM
Just to get things straight, do the following:
1. Disable 802.11b radio;
2. On the 802.11a radio settings, disable data rates from 1 Mbps to 11 Mbps. Make 12 Mbps as Mandatory and all the rest is Supported.
Try that and see if it improves things.
12-28-2016 06:07 AM
unless I'm missing something isn't that how the speed settings for both radios are set up, or is there something else I need to do?
12-28-2016 06:42 AM
This forces wireless clients to operate at HIGHER SPEED.
12-28-2016 06:57 AM
I got what your saying. isn't the following configs doing just that? on 2.4 do0 I'm trying to allow g/n. on 5g do1, I just want N
do0
do1
12-28-2016 09:16 AM
If you are right next to the AP whole testing and you are connected at a high rate, then there is not much else you can do. I have never really compared speeds with different vendors, maybe with Cisco, Meraki and Aruba, but at the end of the day as long as it was stable and they did have good throughput, no one really cared. When you take a home wireless AP/router, they will add their own flavor of "turbo" that works well with some end devices but maybe specific to their own devices. Enterprise vendors follow a standard which doesn't use these vendor specific features.
The only other thing to try is use a different code and see that that helps or not. Your config is fine and as long as your connected to 5ghz, you will get better throughout than 2.4ghz.
-Scott
12-31-2016 04:10 PM
well, I got it going. looks like my AP's (all 3) do not like the 15.3 code. I tried a few versions and all had the same issue. I went down to the 12.4 and bang! 130+ mbps. I'm gonna do some side testing with my 3rd ap with 15.2 code and keep the other 2 operational as is. but so far so good.
only difference I can see is the connection is sporadic on this code. ill hit, for ex., 120 then it drops to 65, back up to 110 etc. on the 15.3 code it was a steady 100-103 mbps.
12-28-2016 02:46 PM
Cisco 2.4 Ghz does NOT support 802.11n because channel-bonding two (out of three) non-overlapping channels is just plain stupid. Other vendors can/may do it but Cisco has put a stop to this.
The reason why I'm recommending with 5.0 Ghz is because there are more channels to play with compared to 2.4 Ghz. If your wireless clients can get a higher speed at 5.0 Ghz then it only means that the 2.4 Ghz channel in the area is very crowded.
