Too many concurrent AP image downloads, AP will not Join
Dennis Mink
peeps,
wonder if any of you have seen this before, trying to join an 1142 on a WLC_SRE version 7.4.
the AP can ping the controller and vice versa.  In the controllers GUI: Monitor>Statisticc>AP join, I can find the mac of the AP that I am trying to get joined.
the details of this mac show:
Last error occurred:      Lwapp discovery request rejected
last occurred error reason: Too many concurrent AP image downloads
Last Join Timestamp:
any idea where I can increase the threshold for this?
I have probably tried once too often.
Please remember to rate useful posts, by clicking on the stars below.
Mate,
Where are the outputs from the APs?
7 Replies 7
Sahil Mengi
When answering Discovery from lap, a WLC evaluates a couple of conditions, one of which is "Resource Conservation Mode", which i think should be happening in your case.
If WLC is doing upgrades, it will limit the number of maximum laps that can join, regardless of platform and code version it is on.
What is the SRE module here, is it a SRE-700 or 900?
What is the number of laps already on it?
Max concurrent downloads should be limited to 10 if i am not missing..
How many laps do you try to join simultaneously, when you see this issue?
I would recommend adding in laps in small groups, may be of 4-5.
Once downloading laps complete the download and REG to wlc, try adding only one lap, remove all other joining laps, or shut there uplink interfaces, and enable them one by one, allowing them to join.
Sahil
Leo Laohoo
Can you please post the following command outputs:
1.  WLC:  sh sysinfo;
2.  AP:  sh version;
3.  AP:  sh inventory; and
4.  AP:  Post the entire bootup process
sys info:
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 7.4.100.0
RTOS Version..................................... 7.4.100.0
Bootloader Version............................... 7.4.100.0
Emergency Image Version.......................... 7.4.100.0
Build Type....................................... DATA + WPS
System Name...................................... RINGWOOD_xxxxxxxxx_WLC
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.1230
IP Address....................................... 192.168.7.1
System Up Time................................... 0 days 0 hrs 8 mins 46 secs
System Timezone Location.........................
System Stats Realtime Interval................... 5
System Stats Normal Interval..................... 180
Configured Country............................... AU  - Australia
--More-- or (q)uit
State of 802.11b Network......................... Disabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 2
Number of Active Clients......................... 0
Memory Current Usage............................. Unknown
Memory Average Usage............................. Unknown
CPU Current Usage................................ Unknown
CPU Average Usage................................ Unknown
Burned-in MAC Address............................ E4:D3:F1:AF:9C:A0
Maximum number of APs supported.................. 0
Trying to join 1142N  LAPs.    when getting the boot up process on the LAP, it endlessly loops in finding a valid WLC, although I have primed them to go to 192.168.7.1.
The WLC log shows:
*spamReceiveTask: Jan 23 09:38:26.863: #CAPWAP-3-DISC_MAX_DOWNLOAD: capwap_ac_sm.c:1716 Ignoring discovery request from AP ac:f2:c5:f3:ea:f0 - maximum number of downloads (0) exceeded
(every 10 seconds).
Will post the bootup as soon as I have access.
Mate,
Thank fully these error messages are so meaning full (NOT).
This problem was caused by the evalution licence not be active. once I accepted the EULA of the evaluation licence, the AP joined!!!
Thanks for the update.
GERARDO MANALAD
I had the same issue after an upgrade. What I did was to reapply the license, then went to the monitor tab> statistics> AP join and click the blue tab on each of the AP that are not registering and click remove. For the once I click removed it registered and allowed to download.
