How add 3850 Switch to existing stack
Hi there,
Can someone help me, I have been assigned to add a 3rd 3850 switch to existing stack, can this be done without the whole stack being rebooted?
I eagerly await your response and appreciate your help in advance!!
It is recommend that all switches running the same IOS version, so.. until add it at stack, updated it.
Look this guide in other post: https://community.cisco.com/t5/networking-documents/how-to-form-a-catalyst-3850-data-stack-and-power-stack/ta-p/3156083
Note: The switch to be added to the stack must be off. Otherwise, the hole stack will reload.
Jaderson Pessoa
*** Rate All Helpful Responses ***
5 Replies 5
Jaderson Pessoa
If you add a new switch under a existent stack.. Just check priority to this not take the root. The switches wont rebooted if the priority is correctly to do not swap the actual root. 🙂
Jaderson Pessoa
Many thanks for the response,
So I just need to set the the priority low so it does not become the master? What about the software version; if it is of the later version that the other 2 in the stack would it reboot the other 2 in the stack or cause problems. Is there a step by step guide configuration you can link too?
Kind regards
Jaderson Pessoa
Many thanks Jaderson for all your help, its much appreciated!!
YOU'RE WELCOME 🙂
Jaderson Pessoa
