How can I view / monitor installed Access points?
Pa0l0
Is there a freeware SW to view installed access points ?
Mark Elsen
 - Not possible with freeware , look into Cisco Prime.
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
What exactly are you wanting to do?
What model APs and WLCs are you running.
*****Help out other by using the rating system and marking answered questions as "Answered"*****
I have installed AIR-AP38021-E-K9 and just would check which are on or failed, transmitting or not.
All other infos could be an optional plus.
Thank you
Do you have a WLC in use or using Mobility Express?
In either web interface you see all the currently connected APs. You don't have a history though.
