How Convert AIR-AP1262-C-K9 standalone AP to controller based AP?
mandy voon
How Convert AIR-AP1262-C-K9  standalone AP to controller based AP? Is that possibe ? how?
7 Replies 7
Leo Laohoo
1.  Go here and download the IOS.
2.  Copy the IOS to the AP and boot the IOS file.
3.  Connect to the network.
After converted to LWAPP, which model of WLC i can use for ?
 any documentation on this?
 Thanks in advance.
First follow these steps to convert to LAP:
http://rscciew.wordpress.com/2014/05/07/access-point-conversion-lap-to-aap-and-vice-versa/
WLC Model: Its all depneds on your requirement.
Its a small enterprize then go for 2500 series otherwise go for 5500 series.
Dont forget to rate helpful posts
as mention in link , the AIR-AP1262N-C-K9 autonomous access points must be running Cisco IOS Release 12.3(7) JA or later to perform the lightweight mode conversion. If not there will not get successful converted?
Hi Mandy,
I think it will not work :)
As per Cisco recommandation:
Access points must be running Cisco IOS Release 12.3(7)JA or later before you can perform the upgrade.
Abha Jha
for conversion refer the belwo link :-
http://www.cisco.com/c/en/us/td/docs/wireless/access_point/conversion/lwapp/upgrade/guide/lwapnote.html#wp156967
From the link you post, i didnt see this model AIR-AP1262-C-K9  able to do conversion.
