how does channel assignment work when doing flex and bridge mode
carl_townshend
Hi All
how does channel assignment work when doing flex and bridge mode? does it use the same radio and channel for both the backhaul bridge connection as it does to serve the clients but just separates the airtime between the clients and backhaul?
cheers
Rafael E
Yes, if you have enable allow clients on backhaul then AP will allow client connection on the same radio as the one it uses for backhaul. This configuration is disable by default.
Saludos,
Rafael - TAC
