How i can Configure Web Policy Pass Through On Standalone AP and add customize webpage
Abhishek Shah
I have Cisco 1040 AP with new code 15.3.3-JAB. I would like to skip the guest user authentication and display only the web page disclaimer option for Guest.
There is a option called web pass through from GUI and its working.
How can i add custom page and also display Accept and Decline button, before client access Internet connection.
Only way it can be done through CLI.
Please let me know, if any one working on same issue..
Thank you in advance....
5 Replies 5
Saurav Lodh
Level 7
Level 7
http://www.cisco.com/c/en/us/support/docs/wireless-mobility/wlan-security/116897-configure-technology-00.html#anc9
dkalinsky
Not sure if Cisco 1040 has this feature, but try to use this commands:
ip admission consent banner [file file-name | text banner-text]
http://www.cisco.com/c/en/us/td/docs/ios/sec_user_services/configuration/guide/12_2sr/sec_securing_user_services_12-2sr_book/sec_cons_feat_rtrs.html#wp1053058
http://blog.ipexpert.com/ios-authentication-proxy-with-consent-feature/
ali aqrabawi
Level 3
Level 3
link below show you how to configure webauth on autonomous AP , and how to configure custom page on the aP
gohussai
Level 4
Level 4
Check the following Cisco document for proper configuration of Web Pass through.
http://www.cisco.com/image/gif/paws/107474/web_pass_config.pdf
Note: If you have a stand alone AP, you will need a 3rd party appliance or software to have the splash page option.
piam.lang
hello,
did you finally find a solution? I am having the same problem with a 3500. It would be great if you share the answer here.
