07-08-2011 12:18 AM - edited 07-03-2021 08:24 PM
How many SSID can be create in a 4404 controller and also in standalone 1250 AP? How many VLANs can be created in eac one?
Thanks ..
Solved! Go to Solution.
07-08-2011 01:15 AM
On the WLC, you can configure upto 512 WLANs and on the AP at a time maximum 16 WLANs can be broadcasted or can be used..
VLANs are nothing but Dynamic interfaces and we can configure max 512 dynamic interfaces on the WLC..
Lemme know if this naswered ur question and please dont forget to rate the usefull posts!!
Surendra
07-08-2011 01:15 AM
Surendra
07-08-2011 01:32 AM
Since software version 5.2.157.0, WLC can now control up to 512 WLANs for lightweight access points. Each WLAN has a separate WLAN ID (1 through 512), a separate profile name, and a WLAN SSID, and can be assigned unique security policies. The controller publishes up to 16 WLANs to each connected access point, but you can create up to 512 WLANs on the controller and then selectively publish these WLANs (using access point groups) to different access points to better manage your wireless network.
Note: Cisco 2106, 2112, and 2125 controllers support only up to 16 WLANs.
Thanks Surendra... ;-)
