how to Assign vlan per port all cisco access point 702w by wlc 5508
kettepong
My environment have WLC 5508 and ap 702w 250 units in my site. I need to config port all ap 702w example port 2 >> Vlan 20 port 3 >> vlan 30
Now i canfig one by one.
Please everyone tell me better way for config one time 250 units.
thank you a lot..
Here is the CLI config involved. If you have list of your AP names you can workout CLI config for all your AP on notepad & then configure this via CLI
config ap lan port-id <port_id> enable <AP_Name>
config ap lan enable access vlan <vlan_no> <port_id> <AP_Name>
Refer this post for more details
https://mrncciew.com/2014/09/26/702w-with-wlc-8-0/
Rasika
*** Pls rate all useful responses ***
5 Replies 5
tadnan001
You can configure multiple APs with Prime templates:
check attached pic. It has link to templates as well as where to insert VLAN details in template.
Fill in rest of template with required information.
Save template and move to selection section and choose your AP's by puting 702W in model column (or use any other selection criteria that suits your environment, e.g. subnet range etc.)
Thank you for answer but my site not have Prime can you tell me how else ?
Rasika
Dear K.Rasika Nayanajith
thank you very much for this command i use in excel first and copy to wlc it work!!.
Glad to hear it and thanks for rating our responses as well.
Rasika
