How to broadcast a secondary SSID ?
johannf
Is it possible to do this. We have 350/1200 ap'r running VmWorks with firmware 12.05T, and it seem that they only can broadcast one.....?
Johann Folkestad
Volda, Norway
I'm not sure if that version of code supports multiple SSIDs but I know the 12.2 code does. Best method is to do it with subinterfaces on the radio and the fastethernet interface. Each subinterface is a different SSID configuration (don't forget the global SSID configuration as well for each one).
