How to change netmask on management interface for wireless lan controller
a17ha9001
I will like to know how to change the management interface on a WLC, the Netmask is currently a /23 but will like to change to a /22.
I noticed that the configuration by default is grayed out when I check the GUI, can I have assistance on best practice how to change the ip address and Netmask and also the risk involved?
Many thanks in advance.
Mark Malone
you can change the mgmt. int under the cli , just make sure all your other devices using that subnet range are changed as well to match , if that's what your now going to be routing instead of /23
http://www.cisco.com/c/en/us/td/docs/wireless/controller/7-4/configuration/guides/consolidated/b_cg74_CONSOLIDATED/b_cg74_CONSOLIDATED_chapter_011011.html#ID239
Configuring the Management Interface (CLI)
    Step 1   Enter the show interface detailed management command to view the current management interface settings.
    Note    The management interface uses the controller’s factory-set distribution system MAC address.
    Step 2   Enter the config wlan disable wlan-number command to disable each WLAN that uses the management interface for distribution system communication.
    Step 3   Enter these commands to define the management interface:
    1. Using IPv4 Address
      • config interface address management ip-addr ip-netmask gateway
      • config interface quarantine vlan management vlan_id
        Note
        Use the config interface quarantine vlan management vlan_id command to configure a quarantine VLAN on the management interface
    Mark Malone
          Note
