HP WX Monitoring with Prime 3.0
matthew gosling
Hi all,
I am trying to set up Prime 3.0 to monitor some HP WX wireless LAN controllers, and don't seem to be having much luck in finding and being able to import MIB;s into Prime.  I was wondering if any one else has done something like this or similar?
M. Wisely
Level 4
Level 4
Prime Infrastructure won't be able to manage your HP wireless kit, it's primarily for monitoring cisco kit. You can add it to HP but it won't be manageable. If you have the HP iMC management platform it can manage your controllers.
