how to check AP antenna??
Is there a way to check the antenna model name of the AP??
2 Accepted Solutions
Hi @JustTakeTheFirstStep
If it is an external antenna, try to see if the model is indicated on the antenna itself.
If it is an internal antenna, possibly in the datasheet of the ap the antenna model is indicated.
But, through CLI, it is not possible to know the antenna model.
6 Replies 6
luis_cordova
Do I understand that there is no way to check the antenna?
Check the AP antenna for what exactly?
Yes. I want antenna model name
Not possible.
