How to configure 3 X 4410N to extend wifi ?
sheberle57
Hi everybody
I would like to configure 3 Access Point (WAP4410N) to extend the wifi in my house. I try it to do several configuration but it doesn't work.
In this configuration, the wifi devices disappears and re-appears constantly. I lose the IP addresses and they all come down only every 5 seconds.
I made screen shots of the 3 terminals in the word document attached below. Can you help me please
Thanks you
Stef
Damon Garner
In order for an AP to work in repeater mode, there must be 50% overlap on the signal and the APs must be on the same channel. For each repeater that is setup the actual throughput is roughly half.
Ok So I changed the configuration about the wireless. I plugged every AP with wire and I have configured it as AP with the same SSID.
I think is the better configuration for actually.
