Hi all,
Customer of mine has 20 AP AIR-BR1310G-E-K9. No controller installed. He use them as Autonomous AP.
Right now he wants indroduce a WLC. Due to that every single AP must be converted in LAP AP.
Anyone can tell me wether this is possible or not ?
is this action free of charge ? Nedd I SMARTENT COVERAGE ?
any Cisco documentation is more than welcome:)
Thank in advance
CARLO
Hi Carlo,
If the customer is planning to use WLC then yes all the AP's has to be converted from IOS to Light Weight (LWAP) AP. This can be done freely provided you have the correct software image. You should be able to download this from the Cisco site and you wont need to have a SMARTNET as long as you can get the images from Cisco site by other means:-)
Below url will guide you with the procedure.
Upgrading Autonomous Cisco Aironet Access Points to Lightweight Mode
LWAPP Upgrade Tool Troubleshoot Tips
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_tech_note09186a008072d9a1.shtml
Also please be aware that "All 1310 AG access points can operate at AP Mode not as Bridge Mode"
Hope this helps.
Najaf
Please rate when applicable or helpful.
Thank
only one question more
Reading the link you sent
I got I can convert all 1310 AG series my AP are 1310G any issue about ?
CARLO
Hi Carlo,
Your AP's should be fine with the upgrades. AP1310AG has dual radio cards (i.e "A" which operates at 5GHz and "G" which operates at 2.4GHz). Your AP has only one radio (i.e "G"). Dual radio or single radio on a AP does not affect the upgrade procedure.
Hope this helps.
Najaf
