06-24-2008 11:11 AM - edited 07-03-2021 04:04 PM
Hi dear,
Could you please give me some clues how to configure AIR-WLC4402-50-K9 in cluster.
Thanks in advance
Best Regards
06-24-2008 05:21 PM
Explain what you are trying to acomplish. Do you mean like in a server environment behind load-balancers?
06-24-2008 11:45 PM
I mean, i want to use the first controller as a primary and the second controller as a secondary..If the primary goes down, the secondary take the role.
06-25-2008 03:39 AM
Basically you configure the ap's to point to the primary, secondary and or tertiary controller. What you can do also is put half of your ap's on one wlc and the other half on the second wlc. Then configure the secondary wlc as the other wlc. You must make sure you also configure the mobility groups which is required.
This doc might help:
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a00809817ca.shtml
