How to configure multple SSIDs on same VLAN (Autonom. AP1231G)
alig.norbert
Level 4
Level 4
Hi all,
I got a couple of AIR-AP1231G (autonomous, without WLC). There are several SSID's mapped to several VLAN's. Everything is fine.
Now, I have to configure a second SSID (with different authentication) on an, already "SSID-associated" VLAN.
Unfortunately, the AP shows me the following error:
"Warning: Vlan xxx already mapped to SSID xxx. SSIDs with same vlan association cannot be attached to the same interface.
Dot11Radio0: VLAN xxx is already mapped to SSID xxxx, SSID to VLAN mapping should be unique on interface".
I know, with WLC440x it can be done. Without VLAN-SSID association on an autonomous it works as well.
What about this setup? Do I have do build up a new VLAN?
Norbert
Rob Huffman
Hi Norbert,
Hope all is well my friend!
Autonomous 1100 and 1200 Series;
You can configure up to 16 SSIDs on your access point and assign different configuration settings to each SSID.These are the settings you can assign to each SSID:
*** Note: SSIDs, VLANs, and encryption schemes are mapped together on a one-to-one-to-one basis; one SSID can be mapped to one VLAN, and one VLAN can be mapped to one encryption scheme.
•VLAN
•Client authentication method
•Maximum number of client associations using the SSID
•RADIUS accounting for traffic using the SSID
•Guest mode
•Repeater mode, including authentication username and password
•Redirection of packets received from client devices
If you want the access point to allow associations from client devices that do not specify an SSID in their configurations, you can set up a guest SSID. The access point includes the guest SSID in its beacon.
If your access point will be a repeater or will be a root access point that acts as a parent for a repeater, you can set up an SSID for use in repeater mode. You can assign an authentication username and password to the repeater-mode SSID to allow the repeater to authenticate to your network like a client device.
If your network uses VLANs, you can assign one SSID to a VLAN, and client devices using the SSID are grouped in that VLAN.
From this doc;
http://www.cisco.com/en/US/docs/wireless/access_point/12.4_10b_JA/configuration/guide/scg12410b-chap7-mbssid.html#wpxref78332
Hope this helps!
Rob
14 Replies 14
Rob Huffman
Hi Norbert,
•VLAN
•Guest mode
From this doc;
Hope this helps!
Rob
Hi Rob,
Thank you, I'm very well.
Great link and it explain that it can't be done:
- vlan vlan-id
(Optional) Assign the SSID to a VLAN on
your network.
Client devices that associate using the
SSID are grouped into this VLAN.
You can assign only one SSID to a VLAN.
Greets,
Norbert
There is a way to do it in that you put all SSIds into the same bridge group and the bridge group is a single VLAN. I was looking at doing this for a client on a WLSE but it was just getting far to complex, also difficult to manage. Its definitly not best practice and doesnt enhance security. Id say it cant be done though technically it can but its not pretty.
I had this issue and investigated it and set it up in a small lab, then decided there was no real way that it would be manageble
Hi Wynneit,
I am looking for how to configure multiple SSIDs on same VLAN. Would you mind explaining me more about it or could you please provide me an example of configuration?
Thank you very much,
Nitass
Hi Nitass,
here is an example with multiple SSID's on the default-vlan (works only on the default one!!!)
dot11 ssid test1
authentication open
authentication key-management wpa
wpa-psk ascii 7 75A6D
dot11 ssid test2
authentication open
guest-mode
wpa-psk ascii 7 64940
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption mode ciphers tkip
ssid test1
ssid test2
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
channel 2412
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
interface BVI1
ip address 192.168.254.21 255.255.255.0
no ip route-cache
ip default-gateway 192.168.254.1
no ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
control-plane
bridge 1 route ip
Hi alig.norbet,
Thank you so much. :-) I'll try and let you know if getting any problems.
Thanks again,
Nitass
Hi alig.norbert,
I'm Nitass's friend i tried your example config but cannot see 2 SSID on client.
I use AP1121G,
Thank.
Jakkrit
WHy would you want 2 ssids on the client? The client will be able to see both ssids if you use mbssid command and connect to either, I will post a config in the next few days for non default vlan if you still need it when I get some lab time.
Hi Both,
This is Nitass. Thank you both very much for help. The reason to have 2 SSIDs on the same VLAN is to separate security policy (i.e. authentication, encryption) on each SSID. Anyway, I have heard from my colleague (Mr.Jakkrit) that he had to create sub interfaces for each SSID to let alig.norbert configuration work. I do not understand why we need to configure like that because actually, you know, we need only 1 VLAN. The test configuration is listed below. Could you please advice?
dot11 ssid test1
vlan 1
authentication …(snip)…
information-element ssidl advertisement
dot11 ssid test2
vlan 2
bridge irb
no ip address
no ip route-cache
ssid test1
ssid test2
speed basic-1.0 2.0 5.5 6.0 9.0 11.0 12.0 18.0 24.0 36.0 48.0 54.0
channel 2412
station-role root
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no ip route-cache
bridge-group 1
interface Dot11Radio0.2
encapsulation dot1Q 2
no ip route-cache
bridge-group 1
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
interface BVI1
ip address 192.168.10.1 255.255.255.0
no ip route-cache
ip default-gateway 192.168.10.254
ip http server
control-plane
bridge 1 route ip
Nitass
Hi Nitass
My sample only works with the default(native)-vlan. So, no vlan configuration, as well no encapsulation config (fastethernet).
The dotRadio- and the fastethernet-interface must be in the same bridge-group. The connection form accesspoint to switch shouldn't be trunk.
BTW. you can only broadcast one single SSID as guest-mode, the second one is hidden.
your config should look somehow like this:
dot11 ssid test1
!!!!!vlan 1
dot11 ssid test2
!!!vlan 2
bridge irb
no ip address
no ip route-cache
ssid test1
ssid test2
channel 2412
station-role root
bridge-group 1
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
interface BVI1
no ip route-cache
ip http server
control-plane
bridge 1 route ip
Greets,
Norbert
Hi Norbert,
I see. Please let me try again and I will let you know if getting any problems.
Nitass
You can broadcast both ssids with mbssid
Noted with thanks.
Nitass
Thank you very much. I got it right now. Anyway, I could broadcast only 1 SSID. I have tried “mbssid” but it did not work. I understand VLAN is needed for mbssid. Please let me know if you have any suggestions. The following is my configuration.
ap#sh run
Building configuration...
Current configuration : 1471 bytes
version 12.3
no service pad
service password-encryption
hostname ap
no logging console
enable secret 5 xxxxxxxxxx
ip subnet-zero
no aaa new-model
dot11 ssid test1
authentication open
guest-mode
wpa-psk ascii 7 010703174F5A575D7218
dot11 ssid test2
authentication open
wpa-psk ascii 7 120D000406595D56797F
username xxxxx password 7 xxxxxxxxxx
bridge irb
no ip address
no ip route-cache
ssid test1
ssid test2
station-role root
bridge-group 1
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
hold-queue 80 in
interface BVI1
ip address 192.168.2.171 255.255.255.0
no ip route-cache
ip http server
control-plane
bridge 1 route ip
line con 0
line vty 0 4
login local
end
Thanks again,
Nitass
