How to connect a secured internet connection to a wireless router?
arunviswanath
I have an internet connection for which i need to provide the username and password before i can connect to the internet.
I need to know whether it is possible for me to connect this wired connection to a wireless router,so that i can share my
internet between my pc and mobile.If possible please tell me how to.
Thanks in advance
Amjad Abdullah
Hi Arun:
If you ask about the possibility then the answer "Yes it is possible".
However, you need a device that supports that the authentication method you use.
For example, if you use PPPoE connection to provide your username and password then you need to get a wireless router that supports that.
Usually smallbusiness wireless routers have couple of options.
You need to check with your provider what is the auth method in use and then buy a wireless router that supports that method.
Amjad
Rating useful replies is more useful than saying "Thank you"
