Whether 40Mhz Bandwidth is supported on 2504 controller
yasaswi55
I found 20Mhz bandwidth enable option in 2504 controller.But what about 40 Mhz .The access points(1142) are dual band...I hope it should support in 2504 controller also.If there is no option of 40Mhz ,Please Correct me
Saravanan Lakshmanan
On all N APs it is supported only on 5Ghz(A-Radio) & not in 2.4Ghz(G-Radio). This feature is platform independent.
Amjad Abdullah
Just like what Sarvanan said, 40 MHz is only available on 802.11a (5GHz) and not on 802.11b/g (2.4GHz).
However, in old versions of code (6.0.182 or something like that) for wirleless controller I remember the 40 MHz was also available for 2.4 GHz (802.11b/g). They recognized later it is not feasible to add it to 2.4 GHz so they removed it from later releases.
Amjad
Rating useful replies is more useful than saying "Thank you"
