How to connect aironet 340 access point to form a LAN?
altenativ
Hello all.
I have an aironet 340 access point and several aironet pcmcia client adaptors. I have a laptop running win nt4 server and the rest running win nt4 client. How should I connect and setup the various devices such that all these laptops can form a LAN? any help will be greatly appreciated! Thank you very much!
kmarrero
Level 4
Level 4
You need to set up the access point and give it a distinctive SSID and give it an IP address that falls within your network. The clients will all have the same SSID as the access point and they will have IP addresses that fall within your network. Below are a few URL's that should help you configure the AP and the clients.
http://www.cisco.com/univercd/cc/td/doc/product/wireless/aironet/accss_pt/index.htm
http://www.cisco.com/univercd/cc/td/doc/product/wireless/aironet/adapters/index.htm
