Load balacing on AP
c.ong
Dear Sir,
Does the AP handle load balancing dynamically?
I know that the client will switch to another AP based on the signal quality level detected and not on signal strength. How about the utilisation on the AP? Will this play a role? If I have 3 APs coexist at one location. Will the clients load balance themselves or more clients will connect to one AP and the other two serve a few of the clients only?
Thanks.
Delon
kmarrero
Level 4
Level 4
You can enable load balancing on the AP which will distribute the user connections accross available access points.
http://www.cisco.com/univercd/cc/td/doc/product/wireless/airo_350/accsspts/ap350scg/ap350ch3.htm
