How to delete images and logs in Cisco 9120axi access points
nikolas-pereira
Hello everyone.
I want to delete some logs inside Cisco 9120axi access points, in the flash filesystem. But, when i try to delete with the command Delete i'm can't find the flash directory.
i have tryed all combinations to find the flash filesystem.
the command delete cores fix my problem
nikolas-pereira
note: I'm running the version 17.9.4a
Mark Elsen
 - Start with a simple 'dir' command ro find the correct name of a flash-related directory (or view them all)
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
