how to delete vlan from ap group
gavin han
How to delete vlan from ap group? I wasn't able find any option to remove vlan from the ap group usin wlc web interface.
Scott Fella
Easy... delete the WLAN from the ap group then add it back:)
You can't just change the vlan.
-Scott
oh my bad. I meant to ask..how to delete WLAN from the AP group.
I guess I had a long night.
In the AP Group, you click on that blue triangle on the right of the SSID. There is a remove or delete there.
-Scott
