How to disable 802.11ac feature "Low Density Parity check[LDPC]" on Cisco Controllers
tpr387001
I observe LDPC is enabled by default on my controller when 802.11ac is enabled and there is no option to disable it.
Is there any command to disable LDPC on my controller.
Rasika Nayanajith
I do not think there is an option. Here is some useful detail about this LDPC
https://supportforums.cisco.com/document/12526916/low-density-parity-check-ldpc-codes
Why do you want to disable it ?
Rasika
Thanks for the reply. I am not able to sniff data packets on Omnipeek wireless capture using AE6000 dongles when LDPC is enabled
