12-15-2022 08:57 PM
How to enable operation status on cisco 9800
12-15-2022 10:36 PM
- Connect to one of those access point just after boot and issue the command show logging , check for anomalies , also review the 9800 configuration with the CLI command : show tech wireless , have the output analyzed by https://cway.cisco.com/
M.
12-16-2022 12:23 AM - edited 12-16-2022 12:23 AM
is this a new setup? Cat 9800 works different way compare to airOS
what version of WLC code running.,
this is changed so you need to create profiles and policy tags:
check below guide step by step :
