How to increase radio output on specific AP via 9800-CL?
ryan14
I am trying to figure out how to increase the radio output/strength for an AP. Is there a KB on how to do that?
Rasika Nayanajith
Once you go to "Configuration -> Wireless -> Access Points" you can select given AP and specific configuration option (Radio specific ) as shown below. More specifically select "Custom" Tx Power Assignment method and select the appropriate Tx power level (1 mean max and each other level is 3dB less from the previous level)
Rasika
*** Pls rate all useful responses ***
6 Replies 6
Rasika Nayanajith
Rasika
'1 mean max' do you mean 1 means lowest output? Thanks.
1 is max for all Cisco wireless
-Scott
How accurate is the decibel reading after the power level? When I set the power level to 1, 5 GHz shows 18 dBm 2.4 shows 1 dBm. When I set it to 7 on 5Ghz reads 1 dBm and setting 8 on 2.4 GHz WLC shows 22 dBm.
Different aps have different output depending on country code and so model.
-Scott
You can see how the tx power maps to a dBm level by using the following commands:
show advanced 802.11a txpower
show advanced 802.11b txpower
-Scott
