12-21-2014 04:18 PM - edited 07-05-2021 02:09 AM
I just recently enabled some additional e-mail alerting from my cisco WLC. Since enabling them i've been receiving constant alerts about a interferer 'WiFi Invalid Channel' being detected and then clearing.
the full message is
Security-risk Interferer 'WiFi Invalid Channel' is detected by 'WAP'.Interferer severity is '2'.
i've done some research on what this is, which from my understanding is either a non-wifi device or wifi device that is transmitting just off center of a standard wifi channel.
However, i could not find anything on how to track down or locate these devices. any insight on how to do this would be appreciated.
12-21-2014 04:43 PM
What is happening is that the ap has detected "something" using a non standard channel. For example, maybe channel 12 on the 2.4ghz. Take a look at the RF with a spectrum and see if you see non standard channels being used.
-Scott
12-21-2014 05:01 PM
We have a few blue tooth devices in that area, i'm wondering if that AP is picking it up as the interferer.
any idea if that is possible?
12-21-2014 05:03 PM
Bluetooth would be detected as Bluetooth to be honest. I don't think that is the case.
-Scott
