03-09-2022 10:03 PM
we have some SSID, traffic will go to central anchor wireless controller from local, so we decide to monitor the status between local WLC and anchor WLC, we could monitor it via syslog as below, but our monitoring team said it's better we can monitor it via SNMP trap, does anyone know how to set SNMP trap in WLC for this kind of log? much appreciate for your support
*mmMobility: Mar 01 16:15:35.301: %MM-1-ANCHORS_DOWN: mm_heartbeat.c:745 All Export-Anchors are down on WLAN 16
03-09-2022 10:46 PM
On anchor controller, go to management >snmp>Trap control >general>link up/down check that. Setup trap receiver address if you want to. If the controller link goes down you will get trap notification.
make sure port 162 is open between wlc and trap receiver.
If you want to be more granular then download wlc mib zip file from Cisco software download center and give it to your network management team, most monitoring tools will allow mibs to be imported and will allow query for specific oid referring to anchor controller/link monitoring.
03-09-2022 10:56 PM
You have 2 Options,
- Send Trap to syslog server ( if you have one and process logs to email when you see the message)
- Monitor with NMS
https://oidref.com/1.3.6.1.4.1.9.9.576.0.3
