How to position the dual-band dipole antennas in 2600 model access points..?
Nithin Jacob
I have quite a no: of 2602E model access points deployed in a particular site.
The access points are ceiling mounted and currently all the 4 antennas for the access points are placed pointing downwards.
Is there any angle or particluar direction in which the antennas for the access points should be placed for optimum coverage....?
Please help..!!!!
Nithin.
Scott Fella
They should be vertical which you have done.
-Scott
Hi Scott,
Thanks for the reply...
Would this position of the antenna yield maximum coverage...?
Nithin.
Yes it will. If you had the ap on a wall, the antennas still should be in a vertical position, either up or down.
-Scott
