How to Prime 2702i on Faroe Islands
jebi
I know we have to use the App to prime our APs, but we are located in Faroe Islands (FO) and the app dosnt seems to support this. How do we proceed from here?
Best regards
Jesper
Derrick Robba
Need a little more detail here, what phone are you using? Do you have cell coverage? What error are you receiving if any.
The link below provides detail instruction for each of the major phone types.
http://www.cisco.com/c/en/us/td/docs/wireless/access_point/ux-ap/guide/uxap-mobapp-g.html#pgfId-71929
good luck.
Hi Derrick & Mohanak,
Thanks for your replies.
We are working on an iPhone with great coverage so there should not be any issues there. I have uploaded the image from our iPhone, and as you can se we are not able to proceed from here.
The device we are working on: iPhone 6+, ios 9.3.
mohanak
Cisco AirProvision is supported only on smartphone platforms and will not operate on tablet, personal, and desktop computers. Cisco AirProvision is supported on the following smartphone platforms:
  • Apple iPhones running Apple iOS 7.0 or higher
  • Android 4.0 or higher
  • Windows Phone 8.0 or higher
Cisco AirProvision is available for download from iOS App Store, Google Play Store, and Windows Phone Store.
Hi Mohanak,
