How to reset AIR-AP1242AG-A-K9 to defaults and keep the static IP
Aaron Alvarado
All,
 whats the command to completely reset a cisco AIR-AP1242AG-A-K9 device but ensure I keep the static IP. these are remote devices and i need to reset them but keep the IP.
Any help will be appreciated
Sandeep Choudhary
If you want to reset the access point to its default settings and a static IP address, use the write erase or erase /all nvram command.
If you want to erase everything including the static IP address, in addition to the above commands, use the erase and erase boot static-ipaddr static-ipmask command.
Don't forget to rate helpful posts
Sandeep Choudhary
Sandeep Thanks..
