How to reset Cisco 5508 WLC (SSO Enabled)
We have two Cisco 5508 WLC and SSO is enabled. If i follow the below steps, will it erase the configuration of both WLC's. Please confirm. Thank you
  1. login to WLC GUI with valid username and password.
  2. Go to Command > Reset to Factory Default.
  3. Click Reset.
Leo Laohoo
To reboot both controllers the command is "reset system forced both".
To factory-default/erase the config, the command is "clear config".
