How to reset Cisco Air-AP1852i admin username and password
Hi all,
I was configuring my new Cisco Air-Ap1852i and set an admin username and password but I forget the password. Now I want to reset the admin username and password, need help in this regard.
Thanks in advance.
Scott Fella
You have to factory reset the AP if unable to access the device. Here is the process:
https://www.cisco.com/c/en/us/td/docs/wireless/access_point/1850/hardware/guide/ap1850hwguide.html#pgfId-33648
-Scott
Scott Fella
-Scott
It worked Thanks
This is not an solution, It will erase all configuration, This can not say password recovery.
I am facing same issue, Can I recover the password only withought erasing any config.
