How to secure point-to-point link - no external RADIUS
ggolding
Trying to find a way to secure a point-to-point link between 2 1310 bridges. The site has no access to an ACS server, and it appears that for some reason (why?) you can't run the "radius-server local" command on a bridge. Would like to use AES & WPA to secure the data but to date have been unable to find anything to see if this can be done.
Really don't want to be stuck with static WEP keys. Is there another alternative?
o-ziltener
I would suggest you to use WPAv2 with Pre-shared key.
best regards
Oliver
