How to set EAPOL-key-timeout in EWC 17.7
randyj
I can't find how to change EAPOL-key-timeout for an AP running EWC 17.7.1   Either CLI or webui
OK, real issue is that I have a couple iPads that won't connect to our network (3 out of 200), the initial handshake sends M1 and M2, and then repeats, never getting any further. These iPads are centrally managed, and have the same profile as all the others. So I am assuming they have the correct passphrase. I noticed in a previous controller this timeout was larger, and I want to see if that resolves the issue
Thanks, that sent me down a different path and I finally found the command:
wireless security dot1x eapol-key timeout <nnnn>
Try this, but never tested.
config advanced eap eapol-key-timeout <time>
Or maybe:
config wlan security eap-params eapol-key-timeout 1000 <WLAN id>
@Flavio Miranda that's AireOS not IOS-XE
