How to setup optional Layer 2 security for a SSID on WLC4404?
david.yu
I have two questions.
1. How to setup optional layer 2 security on a single SSID?
Our ccurent SSID is "SCHOOL"
We're using Web authentication, and I want to setup OPTIONAL layer 2 security either with WPA or WEP.
2. By the way, is it possible to have two OPTIONAL layer 2 security bind to one SSID?
For example, SSID:SCHOOL can be connected with either WEP or WPA or none.
Thanks.
~David
Stephen Rodriguez
David,
On the WLC platforms, we do not have "optional" encryption. If you set the WLAN to use WEP or WPA, you will need to configure the client as such, or the security negotiation will not complete.
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
