How to setup two Cisco Wireless Access Point to be seen as one with automatic balancing in a house ?
Elrick Landon
Hi to all,
I have two Cisco wireless access point (reference = AIR-CAP3702E-E-K9).
Each wireless access point will be pluged to a POE Cisco Switch (2960-XR).
I would like to use it in my house to have WiFi network everywhere.
The target is to have the same SSID to avoid to switch from one to another but i think that the device connected on one cannot change to another even with the same SSID, unless if it loses signal completely ?
Does someone can tell me how to configure properly these wireless access point to be seen as one with automatic/hidden switch between one to other when a wireless device is closer ?
Many thanks for your help in advance.
15 Replies 15
That's good to hear.
Regarding ip http help-path, you can safely remove it as you no longer use http server function on your AP.
It specify where is help files for use by AP GUI screen when AP act as HTTP server. See below
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/https/command/nm-https-cr-book/nm-https-cr-cl-sh.html#wp1031966007
ip http help-path
To configure the help root used to locate help files for use by the user’s current GUI screen, use the "ip http help-path" command in global configuration mode.
ip http help-path url
To verify in CLI you can use " show ip http server all" command.
Rasika
*** Pls rate all useful responses ***
