11-13-2013 09:44 PM - edited 07-04-2021 01:15 AM
Hi All,
we have 4 x WLCs 4400 in two 6500 core.
For any changes we made we have to do in 4 WLC ie in 4 places and
we are thinking of shutdown 2 x WLCs so we are using only 2 WLC at at times.
Not sure how about do this.
Any suggestions are much appreciated.
LE.
Solved! Go to Solution.
11-14-2013 02:44 PM
Sorry. I thought you were talking about 5508.
Ok, WiSMs? Run the follwing command:
no power enable module 9.
11-14-2013 11:56 PM
Shut the interface and port-channel down that connects the WiSM to the 6500.
11-13-2013 11:24 PM
How do you monitor your wireless environment ? Do you have WCS/Prime to manage these controllers ?
As long as total AP count you have can be managed by two 4400, then there should not be a problem.
Is it worth reducing the number of WLCs, because of configuration has to replicate each of them ? I would get Prime & then manage all of the controller through that (config changes, monitoring, etc)
Rasika
**** Pls rate all useful responses ****
11-14-2013 04:42 AM
Hi Rasika,
What Cisco Prime flavour you recommend? Can you provide a link, please?
11-14-2013 05:16 AM
Florin,
I would use a version that supports your WLC code. The only version I would stay away from is NCS 1.2. Prime Infrastructure 2.0 is the latest release but your 4400's has to be running v7.0 at least.
As far as removing two WLC because changes in configurations has to be done on all four... To me, I just don't see how this is an issue. If I had 10+ wlc's then I would probably hate it. How often are you making changes to want to remove 2 wlc's? If you learn the commands on the CLI, it's easy to cut and paste into each telnet/ssh session.
If you have enough licenses on 2 to support all AP's like the other stated, then maybe use the other two as guest anchors if you don't have any and if you have a separate guest ssid.
11-18-2013 03:24 PM
Hi Scott,
we do not have any management software for these WLCs.
is there any way to find out the average number of people per month that logon onto a Guest Wifi SSID?
LE.
11-18-2013 03:28 PM
There is not. You would need WCS/NCS or Prime.
Scott
Help out other by using the rating system and marking answered questions as "Answered"
11-18-2013 03:29 PM
You'll need something like WCS/NCS or Prime Infrastructure.
Otherwise, if you have staff with knowledge skills, you can poll the WLC for the details you want using SNMP and PERL scripting.
11-14-2013 02:15 PM
Hey Florin,
I've got WCS version 7.0.230.0 and I'm managing WiSM1s (7.0.235.1), 5508 (7.5.102.0) and WiSM2s (7.5.102.0).
This is a known "bug" but no one has bothered fixing in PI (I was told).
I have no PI to verify but if your PI is, say 1.2, and you upgrade the firmware of your WiSM2/5508 to 7.5, it'll still be there.
11-14-2013 03:22 AM
Are you just using 4 for redundancy purposes?
Do you have enough AP licences to enable you to shut down two of them?
I would look to shut them off in a maintenence Window because any Access Points which are associated to the ones you are shutting down will have to reassociate with another controller, which will cause some downtime.
Personally, unless you are 24/7, I would just shut two of them off in non office times and allow any aps to reassociate with the remaining live controllers.
May be worth seeing if Cisco will buy the spare 2 4400's back from you and look into 2x 5508's and High availability as this will provide resilience and not just redundancy which is what you have now.
11-14-2013 02:16 PM
Hi Devils_advocate,
Yes, they are for redundancy purpose and we have enough AP licences to run only 2.
We make changes several times/week and sickof make changes in 4 places and we are in a process of getting the
new WLC5500 in a few months.
Please advise how to shutdown 2 x WLC.
Le
11-14-2013 02:21 PM
Go to the back, there is a power switch above the power cable. Flip the switch. Done.
11-14-2013 02:27 PM
Hi LeoLaohoo,
They are Wism-slot9-1 , Wism-slot9-2 etc in the 6509 Core switches so I do not think there are a power switch but
I will check it out.
Le
11-14-2013 02:44 PM
11-14-2013 03:24 PM
We have WLC1 & WLC2 in core 1 and WLC3 & WLC4 in core 2.
what command or can we shutdown WLC1 in core 1 and shutdown WLC3 in core 2? to keep a load balance
instead of shutdown all WLCs in either core 1 or core 2
Le.
11-14-2013 11:56 PM
