How to Turn on Radio on 1522E AP With 2504 WLC
rcowan
I have a 2504 WLC with two 1522 AP's one is Root the other Mesh the 802.11b/g/n/     Admin Status says Up but the Operational Status says down. How can I turn this on? When I change the Admin status to enable I get a "Error in  Enabling Admin Status"
7 Replies 7
Saravanan Lakshmanan
Looks like you're not using right power supply/source. use right power injector and try.
get traplog from WLC.
Thanks for the Response.
I was thinking the same thing, a power problem and even swapped the POE with a new one.
We have over 40 sites up with the metal POE80U-560(G)-C-R injectors.
I will try to get a Traplog form the WLC and get it posted.....
Trap Log results
Hope this is enough...
1552E supported poe - 56 VDC power injector AIR-PWRINJ 1500-2= only.
Hi Saravanan,
But the POE80U-560(G)  is the same specs as the cisco AIR-PWRINJ 1500-2=, then why the 1552E doesnt power up. PoE injectors are just silent devices to feed power.
In case where we have one power source and 5 Access Points in the same IDF location, we have used 95W/Port switches to power the 1552E access Points.
Appreciate your reply.
Karthikeyan
Solution Architect (ICT Business)
You have configured the power injector on the AP?
Wireless -> Select AP -> Advanced
Power Over Ethernet Settings
- Power Injector State enabled
Chris
Hi Mooncat76,
We tried these option, still the PoE injector doesnt detect the Access Points.
