How to update AP name and locationHierarchy using Cisco Prime APIs
dcollin5
Can anyone provide an example of  updating the AP information using the Cisco prime APIs, and also what XML Format is accepted by Prime?
Im trying to use the webacs/api/v4/op/apService/accessPoint-PUT?_docs, but not sure if its correct, as the response is always 500 for my input.
Ideally I want to update the following two parameters in the api/v4/data/AccessPointDetails page.
<name>
<locationHierarchy>
marce1000
 - Try the following :
<?xml version="1.0" encoding="UTF-8"?>
<apCandidate>
<apNames>
<apName>AP-NAME</apName>
</apNames>
<accessPointConfiguration>
<name>NEW-AP-NAME</name>
<locationHierarchy>
<location>
<locationName>NEW-LOCATION-NAME</locationName>
</location>
</locationHierarchy>
</accessPointConfiguration>
</apCandidate>
 M.
dcollin5
Thank you. It didnt work.
Actually, the API information was correct - /webacs/api/v4/op/apService/accessPoint.
I was posting auth_headers "Content-Type": "application/json", When I should have been using Content-Type": "text/xml",
 e.g.,
<?xml version="1.0" ?>
<unifiedApDetailsDTO>
<accessPointId>{}</accessPointId>
<name>{}</name>
<location>{}</location>
<mapLocation>{}</mapLocation>
</unifiedApDetailsDTO>
I want to update the MAP location. Basically, get the AP to show up on a WiFi Map. Is it possible to specify a map using the /webacs/api/v4/op/apService/accessPoint end point? Note, I tried a combination of your suggestion, but that did not work <locationHierarchy><location><locationName>NEW-LOCATION-NAME</locationName></location></locationHierarchy>
dcollin5
Just to note, I dont seem to be able to update the following tag:
"<locationHierarchy>Root Area</locationHierarchy>"
dcollin5
As a reference, here is the code I am writing.
https://github.com/dcollin5/ciscoprime-update-ap
