Can a Cisco Business 150AX Be Configured as a Mesh Extender
Hello, I have bought two 150AX access points and I fear that the second one cannot be configured as a Mesh Extender.
I found a document describing how this is done on the older 140AC models: https://www.cisco.com/c/en/us/support/docs/smb/wireless/CB-Wireless-Mesh/kmgmt-3144-cbw-mesh-role-selection.html
Is this possible on 150 AX or do I need to buy another AP ?
Thank you kindly for your help
Hello and thank you for the prompt answer. It turned out that the 150 AX can also be configured in Role "Mesh Extender" by following the same guide I linked in my question. The issue I had was that I forgot to check the "advanced configuration".
glad suggestion helped and you able to proceed with config.
BB
