01-14-2024 06:16 AM
I want to update my Aironet access point firmware and need some help. I'll try to give as many as relevant info as I can:
- 2x AIR-AP1815I-E-K9 Access Points
- No separate controller and one of the Access Points is acting as controller (depending on which one comes up first)
- Current firmware version: 8.4.100.0
Question 1: When I go to the Cisco site to download firmware I have to chose between 'Cisco Mobility Express' and 'Lightweight AP Software'. Which one do I chose in my scenario? It's this site: https://software.cisco.com/download/home/286306794/type
Question 2: I'm attempting to update through the controller web interface (see attached screenshot). Am I correct to assume that updating from here fully updates the access point? Or does it only update the controller software?
Thanks in advance
Solved! Go to Solution.
01-14-2024 09:00 AM
- You will only update the AP with mobility express ; client APs will download new software from the AP running Mobility Express controller software ,
M.
01-14-2024 09:00 AM
M.
01-14-2024 11:47 AM
Ah that's good to know. Thank you very much for your help.
01-14-2024 11:41 AM
what WLC controller ?
check the upgrade process of WLC and AP :
01-14-2024 11:48 AM
I'll take a look. Thanks.
