how to upgrade WLC code via cisco Prime infrastructure?
dhamaljaideep
what are the steps to upgrade a WLC  via cisco prime infrastructure?
mohanak
The software image dashboard displays the top software images used in your network and allows you to change image requirements, see the devices on which an image is running, and distribute images.
Step 1 Choose Inventory > Device Management > Software Images and click Image Dashboard in the top-right corner of Software Image page.
Step 2 Click a software image name to display details about the image.
Step 3 Do any of the following:
http://www.cisco.com/c/en/us/td/docs/net_mgmt/prime/infrastructure/3-0/user/guide/pi_ug/maint_images.html
Thank you mohanak for reply, but will there be any problem if we upgrade wlc via cisco prime and what will be the effect on the access points connected to WLCs.
Saw this topic and wanted to ask. If prime wants to upgrade software version on wlc can it do so using.aes file? if not what file is allowed? Its supposed to show the image file in the image summary dashboard on the left hand side also and not only in repostory right?
U
